- Large Rear Window Template
- Shawn DUFFEE
31 Oct 2021 15:38 #1
by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Large Rear Window Template
Good to hear Warren. Thanks again for sending those to me. That was very kind.
30 Oct 2021 23:27 #2
Replied by Warren Hampton on topic Large Rear Window Template
Shawn, Template came home today... box looks good so no problems Warren
22 Oct 2021 19:00 #3
Shawn, Template is on the way. USpostal service Tracking # 9461211108036818922945 Lady said between 7 to 10 days
13 Oct 2021 14:28 - 13 Oct 2021 14:50 #4
Had to take wife in to have a tendon surgery on shoulder. Did find templeate send mailing address to me This email address is being protected from spambots. You need JavaScript enabled to view it. get window before doing any cutting ... Temp should be 1/8th bigger that window for the seals... SO CHECK ! Seal and window can be a bitch to install so have two people. Be sure both bottom are the same. Window top and bottoms are diff. Just check to my Forney project and marked temp. I just order both from Vern at Skyport 803 360 2961 Oh 3 inches above the the external longeron that is below the side windows
Last edit: 13 Oct 2021 14:50 by Warren Hampton.
- Shawn DUFFEE
12 Oct 2021 17:10 #5
by Shawn DUFFEE
Thank you Warren. Please keep me posted.
12 Oct 2021 00:37 - 12 Oct 2021 00:40 #6
Lots of large rear windows are not the Forney size. I may have the Forney. It is an Alum cut out I will check on it tomorrow! Warren H.
Last edit: 12 Oct 2021 00:40 by Warren Hampton.
