- I need Wing Installation and rebuilding the nose strut advice
27 Jun 2024 23:55 #1
Replied by Warren Hampton on topic I need Wing Installation and rebuilding the nose strut advice
HOW THE HELL DID HE PUT THE FORK ON WITHOUT THE FRICTION i WOULD NOT WANT TO FLY LOOSE LIKE THAT!
- RP J
22 Jun 2024 14:07 - 22 Jun 2024 14:08 #2
by RP J
Replied by RP J on topic I need Wing Installation and rebuilding the nose strut advice
Is the chain he mentions at 2:45 really necessary? It seems like it would be noisy and that it would hang down low close to the tire and potentially could get caught up on a bolt head or something.
Is the wheel falling off an issue? Seems like both snap rings failing would be unlikely but I am not an AP/IA.
Last edit: 22 Jun 2024 14:08 by RP J.
- John Reed
09 May 2024 16:25 #3
by John Reed
Replied by John Reed on topic I need Wing Installation and rebuilding the nose strut advice
I came across this gem from Danny McGee and friend. Thanks Danny.
- John Reed
08 May 2024 18:39 #4
by John Reed
Hello , Do I service the strut with 5606 the usual way by getting the air bubbles out of the strut, or do I simply add 5606 to the strut without doing any of that? Thanks.
- Keith Whitcomb
01 May 2024 13:10 #5
by Keith Whitcomb
Replied by Keith Whitcomb on topic I need Wing Installation and rebuilding the nose strut advice
I am an A&P in Georgia. If you have questions, you can call me @ 404-580-7008
- John Reed
01 May 2024 10:10 #6
by John Reed
Can anyone recommend someone who can rebuild/overhaul a Ercoupe Model 415 forked nose gear strut - hopefully close to Livermore CA? It was rebult once before but still leaks so I would like a specialist to take a look at it.
John
John
