- Breather Tube Routing
- Dennis Tar
05 Oct 2020 07:07 #1
by Dennis Tar
Replied by Dennis Tar on topic Breather Tube Routing
I think it was worth doing & reduced but did not totally eliminate the oil blow by.
More work than I thought since I needed to remove the nose bowl to get to the breather outlet which means the prop also had to come off. I have a C-85 which was upgraded to a C-90 at overhaul so maybe that added pressure in the crankcase?
Dennis
Dennis
- Steve Westlund
04 Oct 2020 22:30 #2
by Steve Westlund
Replied by Steve Westlund on topic Breather Tube Routing
Hi Dennis,
How did the oil breather extension and tube rerouting work out for you?
Thanks,
Steve
Thanks,
Steve
25 Sep 2019 18:57 #3
Replied by Matt Gunsch on topic Breather Tube Routing
I knew I saw that SB, I just could not find it when I went looking for it.
- Dennis Tar
25 Sep 2019 14:25 #4
by Dennis Tar
Ron -Thanks that,s what i was looking.
Dennis
Dennis
25 Sep 2019 00:06 #5
Replied by Ronald Raty on topic Breather Tube Routing
Look at Forney SB 108. I think that is the only official information.
www.univair.com/content/FOR-SB-108.pdf
The following user(s) said Thank You: Dennis Tar
24 Sep 2019 21:44 #6
Mine exits the cowl just forward of the exhaust pipe, I thought I saw a Service bulletin on routing but I can't find it right now.
