Oil temp gauge
  • Gerald Nograsek
09 Oct 2021 21:07 #1 by Gerald Nograsek
Replied by Gerald Nograsek on topic Oil temp gauge
Thanks, Ill give them a try!
  • Edward Moore
09 Oct 2021 21:02 #2 by Edward Moore
Replied by Edward Moore on topic Oil temp gauge
Check keystoneinstruments.com - web page gives all info - they have been around for ages and repair, etc. If they can't help you I'll be surprised!
  • Gerald Nograsek
09 Oct 2021 16:56 #3 by Gerald Nograsek
It actually measures 2 1/4. I have the matching oil pressure. Gauge. I have seen them in other Ercoupe’s. . They are called “tulip pointer gauges and I believe the were made by Stewart Warner. I have been checking others sites with no luck eBay etc).
09 Oct 2021 12:54 #4 by Warren Hampton
Replied by Warren Hampton on topic Oil temp gauge
Just noticed you have mounting screws. org had surface mounted 2 " . Is it 2", 2 1/8 "or 2 1/2" There are a bunch of Auto on the net too.
  • Gerald Nograsek
09 Oct 2021 07:19 #5 by Gerald Nograsek
Aircraft Spruces gauge is “close” to the one I’m looking for, Univair’s is not. I have already contacted Vern and unfortunately he did not have anything.
Thanks for your help.
08 Oct 2021 22:10 #6 by Warren Hampton
There are new one on market., Univair $101. Aircraft Spruce 60 " $ 90. And Vern at Skyport can likely fix you up with a used one.803-360-2061
