- Prop index or balance
30 Oct 2023 22:13 #1
Replied by Warren Hampton on topic Prop index or balance
Hi Don, Chuck told me to set the prop after the Mag click Chuck number is, 614-738-8604 think about an wonder how you are doing after the big blow how did the house far?
29 Oct 2023 11:02 #2
Replied by Larry Snyder on topic Prop index or balance
Should be 10 and 4 as you’re facing the front of the plane. There was a good article in the Capers a couple years ago about that. Maybe somebody out there remembers the issue.
- Don Abbott
29 Oct 2023 10:49 #3
by Don Abbott
Prop index or balance was created by Don Abbott
Got the Alon back from its annual. The shop said they indexed the prop. When the engine stops I have prop blades at 11 and 5 o'clock. I now have a significant fibration anywhere below 2300 RPM. Does any one have the correct indexing information? The numbers are: C90-16-F with a McCauley 7150.
Don Abbott
Don Abbott
