- Alon/M10 Winterization Kit
- Mike Then
15 Feb 2018 12:52 #1
by Mike Then
Replied by Mike Then on topic Alon/M10 Winterization Kit
Ideally, 180-200 is best to boil off moisture/bad stuff. Though it is nice to have a cowl structure that provides such good airflow, anything below 150 is not good.
- Gordie Meade
14 Feb 2018 19:46 #2
by Gordie Meade
Replied by Gordie Meade on topic Alon/M10 Winterization Kit
Interesting. I have no clue as here in Florida, even in the dead of winter the oil temp is in the 140s and in the summer near 200.
- Mike Then
14 Feb 2018 15:20 #3
by Mike Then
Well, I'll answer my own post.
Yes, you can expect a 10-15 degree F higher temps when you cover the opening below the propeller. Conditions were OAT 35F, 2200 rpm, 110F oil temp rose to 120-125.
Mike
Mike
- Mike Then
09 Feb 2018 12:51 #4
by Mike Then
Alon/M10 Winterization Kit was created by Mike Then
Hi, I am a new M10 owner.
Does anyone have Alon or M10 experience using the winterization kit? Basically, a plate covering the cowl opening below the prop.
I see where the 415 guys/gals use it, and report about 10 degrees F warmer oil temps, or higher.
Just wondering if I could expect about the same performance on an M10. I would think so.
Thanks!
Mike
Thanks!
Mike
