- Fuel Primer Repair
Fuel Primer Repair
- Donald Hudson
13 Oct 2021 23:57 #1
by Donald Hudson
Replied by Donald Hudson on topic Fuel Primer Repair
Thanks for the info.
Don
Don
13 Oct 2021 23:13 #2
Replied by Warren Hampton on topic Fuel Primer Repair
You can service your new o-rings with fuel proof grease every couple of years to help keep them from getting flatsided. the same stuff that came with your new o-ring kit.
- Donald Hudson
21 Aug 2021 16:39 #3
by Donald Hudson
I bought a kit from Aircraft Spruce.
21 Aug 2021 16:25 #4
Replied by Matt Gunsch on topic Fuel Primer Repair
depends on your A&P, if he is comfortable with you doing it. You do have to use aircraft o-rings and not what you get from harbor freight.
- Donald Hudson
21 Aug 2021 15:22 #5
by Donald Hudson
Fuel Primer Repair was created by Donald Hudson
Is replacement of the "O" rings in my Ercoupes' fuel Primer OK under owner maintenance. From research on the internet, some say yes some say no.
