Fuel Tank Gaskets
19 Sep 2021 21:32 #1 by Larry Snyder
Replied by Larry Snyder on topic Fuel Tank Gaskets
Go to RealGaskets.com. They have fuel and oil dipstick gaskets that work great on our Ercoupes.
  • Shawn DUFFEE
19 Sep 2021 20:59 #2 by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Fuel Tank Gaskets
I have never seen a cap with a cork gasket. The Cessnas I owned had rubber gaskets. The Ercoupe tanks I have have rubber gaskets.
Have you looked at Wag Aero or similar for a gasket of the same size? I’m sure there is one out there that has the same dimensions.
  • Anthony Fitzgerald
15 Sep 2021 15:37 #3 by Anthony Fitzgerald
Fuel Tank Gaskets was created by Anthony Fitzgerald
I am wanting to replace the gaskets on the fuel caps in the wing tanks on my Ercoupe. My plane has rubber gaskets on there now and I see that Univair only seems to offer cork gaskets. Which material (rubber or cork) is the best to use? If rubber is best, where can I locate those gaskets?
