- C-75 engine with a "C-85 Cam"
01 May 2022 22:23 #1
Replied by Matt Gunsch on topic C-75 engine with a "C-85 Cam"
the TCM parts manual shows the same cam for both engines.
30 Apr 2022 14:55 #2
Replied by Larry Snyder on topic C-75 engine with a "C-85 Cam"
There is no difference between a C-75 and a C-85 except carb jet and prop. Guess that means EVERY C-75 has a C-85 cam!
- John Farrell
30 Apr 2022 14:52 #3
by John Farrell
C-75 engine with a "C-85 Cam" was created by John Farrell
Looking at an ERcoupe whose owner advertises having a C-75 engine with "C-85 Cam." What does that mean exactly: does it produce 85 HP on takeoff or at cruise? Also does it require a C-85 prop?
