Garmin G5 or similar EFIS
15 Aug 2023 21:42 #1 by Matt Gunsch
Replied by Matt Gunsch on topic Garmin G5 or similar EFIS
I installed the experimental AV30 just for the reason Larry said,
  • Ken Ballenger
13 Aug 2023 19:30 #2 by Ken Ballenger
Replied by Ken Ballenger on topic Garmin G5 or similar EFIS
Thanks for the prompt reply, Larry.
13 Aug 2023 19:25 #3 by Larry Snyder
Replied by Larry Snyder on topic Garmin G5 or similar EFIS
My idea is, and it's not worth much, that as long as you have the primary instruments required in 1946 (airspeed, compass, altimeter) then anything you want to add is supplemental only for safety and do not require special TSO approval. The exception is transponder/encoder/ADS-B which ATC depends on for safety.
Fire away!
  • Ken Ballenger
13 Aug 2023 19:19 #4 by Ken Ballenger
Garmin G5 or similar EFIS was created by Ken Ballenger
Thanks for all the feedback about 4-point restraints.  My next question deals with the G5 or similar EFIS.  When I first bought my 415D last year, the previous owner said I could install the experimental version of the Garmin G5 ($1000 dollars less than the certified version) because the Ercoupes were built prior to the advent of TSOs. My hangar manager, who is an A&P, is not so sure.  I asked another avionics tech and he didn't know either.  Any knowledge out there on this subject?  Thanks.
