- Ercoupe 415C Nose Strut rebuild kit.
- Tad Daughters
12 Jul 2025 22:53 #1
by Tad Daughters
Replied by Tad Daughters on topic Ercoupe 415C Strut rebuild kit.
My AI, Matt Gunsch, region 8 director, tells me that there is a multilayer shim for the strut the can repair a worn strut, and in my case, cure the occasional shimmy.
- John Reed
16 Feb 2025 18:57 - 16 Feb 2025 19:00 #2
by John Reed
Replied by John Reed on topic Ercoupe 415C Nose Strut rebuild kit.
It's most likely the nose strut Orings. I am going to buy the ones listed in the Ercoupe parts catalogue, and the Univar SK-31A-LB kit. For some reason the kit has one Oring a different size - but I'll cross that bridge when I come to it. It was resealed a few years ago so I'll be looking for the Oring size as a possible factor creating the leak. Thanks.
John
John
Last edit: 16 Feb 2025 19:00 by John Reed.
16 Feb 2025 16:52 - 16 Feb 2025 16:53 #3
Replied by Brooks McNew on topic Ercoupe 415C Strut rebuild kit.
What problems are you experiencing?
If it's a seal problem, the Alpha Aviation MLG seal kit is a good way to go. Get their optional hone tool so you can make a nice smooth surface for the new cup seals, and make sure to use the new fluid (the new seals use DOT 3 brake fluid instead of red hydraulic fluid).
One word of caution I received from Vernon... There's a snap ring involved with disassembling the MLG strut. Don't lose them! Pretty much everything else can be replaced but nobody has that snap ring in that size anymore.
Last edit: 16 Feb 2025 16:53 by Brooks McNew.
- Keith Whitcomb
15 Feb 2025 15:17 #4
by Keith Whitcomb
Replied by Keith Whitcomb on topic Ercoupe 415C Strut rebuild kit.
Vernon Gregory @ skyport. He sells everything Univair sells. I rebuilt all 3 gear on my Alon with parts purchased from him.
- John Reed
15 Feb 2025 13:36 #5
by John Reed
Ercoupe 415C Strut rebuild kit. was created by John Reed
Howdy,
The Ercoupe 415C I am maintaining needs a strut rebuild. Does anyone know if a strut rebuild kit is available out there?
John
John
