- Recommendations
Recommendations
29 Mar 2025 10:29 #7
Replied by Mac McCormick on topic Recommendations
Roger that. It has an inop tail beacon right now that I need to send in for repair, I don't have the old tail light unfortunately. I found a 14v Grimes tail light on Aircraft Spruce and will look it up again.
As for the Transponder it currently has a Narco AT 150 TSO which weighs 2.3 lbs and takes up a chunk of panel. Hoping I can rebuild the panel to look as original as possible with smaller electronics. Am open for suggestions/help on that.
29 Mar 2025 08:45 #8
Replied by Larry Snyder on topic Recommendations
Can you put the old Grimes beacon back?
I’ve been using a KT-76A as long as I’ve had the plane, 20 years. I’ll bet it’s a little heavier than the new ones. If you have the funds, what about a tailBeaconX/AV30 combo?
29 Mar 2025 08:29 #9
Recommendations was created by Mac McCormick
Good morning, got Tweety back in the air after a loooooong maintenance cycle. Annual went south a wee bit and she needed a lot of TLC. I'm looking for recommendations for a replacement tail light to temporarily take the ADS-B tail beacon off to send in for repair and for an as light a weight compact of a transponder as possible to help shave off a pound or two.
