- 415-C Engine Mount Offset/Angle
- Michael (Todd) Owenby
25 May 2025 07:01 #1
by Michael (Todd) Owenby
Replied by Michael (Todd) Owenby on topic 415-C Engine Mount Offset/Angle
Thanks tons. I believe adjusting the thrust angle down to spec was the missing piece for the sim. Great site, too. Thanks again.
23 May 2025 20:52 #2
Replied by Ronald Raty on topic 415-C Engine Mount Offset/Angle
Here is a link to the drawing for the engine mount.
www.ercoupe.info/uploads/Main/drawings/a-654.jpg
It shows the thrustline angled 3.5 degrees to the right of fuselage CL, and 5 degrees down from the fuselage centerline. Lots of other good Ercoupe drawings at this site, also.
The following user(s) said Thank You: Michael (Todd) Owenby
23 May 2025 17:52 #3
415-C Engine Mount Offset/Angle was created by Michael (Todd) Owenby
Perhaps an odd question but I'm trying to find the above values. I've read the engine is mounted slightly off-center but no definitive amount. I've also read the engine is mounted on the centerline but slightly angled to the right. I've also read (and seen in pics) a significant downward prop angle, but also seen pics that show basically no downward angle (i.e. Smithsonian).
I'm not an owner (yet) nor have I flown one. In the meantime I'm trying to build an accurate flight model in X-Plane.
Thanks in advance.
Thanks in advance.
