- Heavy wing
Heavy wing
17 Jan 2026 17:10 #1
Replied by Larry Snyder on topic Heavy wing
Read SB-35 on how to trim the ailerons. It seems a bit wacky - bend down the trailing edge of the aileron on the light side. But it works. It might take some iterations, do it in tiny increments.
29 Nov 2025 11:57 #2
Replied by Brooks McNew on topic Heavy wing
I don't know if this is the same for a Forney, but I had good results using the process from the rigging guide. Basically, get the ailerons in rig such that the trailing edges are fair with the trailing edges of the center section. If, after that, there is a heavy wing - the extreme trailing edge of the opposite wing (the "light" wing) gets bent downwards.
27 Nov 2025 11:34 #3
Replied by Matt Gunsch on topic Heavy wing
if the plane was damaged, you should check to make sure the plane is still square, measure from the same point on each wing, to a matching point on the tail, each side should measure the same, Look at the trailing edges of the ailerons and make sure they have not been bent to trim a previous issue. If everything measures out you can adjust the left aileron down 1/2 or 1 turn on the rod end and see how it does. Anytime you adjust a rod end, check the witness holes on the body of the rod end and make sure you cannot pass a piece of safety wire thru the holes. if you can, you need to adjust other ends until you cannot pass the wire thru.
- Frank Hamelly
23 Nov 2025 08:06 #4
by Frank Hamelly
Heavy wing was created by Frank Hamelly
Hi. 1960 Forney. Left wing is heavy even after aileron adjustments to counter it. Rudders appear to be straight with nose gear positioned straight. Plane does have previous damage (possibly ground damage as according to logs, only several fuselage skins were replaced. Any ideas? Mike.
