- Informational note 1
- David Gilson
13 May 2026 21:02 #1
by David Gilson
Replied by David Gilson on topic Informational note 1
Update. I got my 337 approved today for the upgrade. Now the open question is how to change the model number in the faa records. The fsdo is pointing me to a dar so I've contacted him for the next paperwork step. As is usually the case, it seems the wrenching part is going to be much easier then the pencil part. I keep everyone updated. For something that has been done presumably many times in the last 70 years, it seems to be a state secret.
24 Apr 2026 17:50 #2
Replied by Matt Gunsch on topic Informational note 1
You do not rivet a new panel over the old panel, it has to be drilled off and the new one fitted and rivetted in place, and must be done by a A&P, and the work inspected by an IA. There is more to the conversion than just the stainless steel sheet.
08 Apr 2026 19:24 #3
Replied by Brooks McNew on topic Informational note 1
David,
That's kind of what I was wondering about too. Stainless to Aluminum isn't terrible for galvanic activity, but with those two sandwiched together you'll end up with a goopy film of oil/fuel/water wicking in and out between them.
Keep this thread updated I'm interested to know what you end up doing!
- David Gilson
07 Apr 2026 15:31 #4
by David Gilson
Also, I've got a parts plane that I'm going to remove that panel and use for a template for a new stainless sheet
- David Gilson
07 Apr 2026 15:30 #5
by David Gilson
I spent a bunch of time in 43.13B last night and it doesn't really cover covering of an existing panel. There seems to be a possible issue with dissimilar metals and galvanized reactions/electrolysis if you just rivet on top of each other. I'm gonna look at bonding them together and see where that takes me
06 Apr 2026 19:49 #6
I'm also interested in doing this. From what I've heard, you just rivet the new skin on top of the existing one. The new skin seems to be supplied with a hole for the nose fuel cap.
I'm guessing that it's just a case of drilling out a bunch of rivets, then match-drilling the new skin before re-riveting.
Very interested to hear from people who have don this before!
