- charging the battery
17 Jun 2019 23:19 #1
Replied by Matt Gunsch on topic charging the battery
read up on what type of charger to use, if you use the wrong type, you can toast the battery
- Henry Pasquet
17 Jun 2019 08:48 #2
by Henry Pasquet
Replied by Henry Pasquet on topic charging the battery
Aircraft batteries are often damaged by a complete discharge. Check it closely after you charge it. I had to replace mine after a ground check of the radio and not turning off the master.
16 Jun 2019 15:09 #3
Replied by Larry Snyder on topic charging the battery
Just charge it like any battery.
Suggestion for the future: always leave your beacon switch ON. That way, if you leave your master on you should see the beacon flashing and can turn the master off. I always leave my beacon and nav light switches on.
- Dennis Tar
16 Jun 2019 14:20 #4
by Dennis Tar
charging the battery was created by Dennis Tar
Any advice to a brand new 415C owner who left the master on and now needs to charge the battery
