- Removing the Cowling
18 Nov 2019 20:27 #1
Replied by Matt Gunsch on topic Removing the Cowling
It is so easy even a pilot could do it
- Steve McNew
18 Nov 2019 14:51 #2
by Steve McNew
Replied by Steve McNew on topic Removing the Cowling
I tend to put the screws back in the holes they came from, secured by tape. (Not all are the same size) My A&P prefers to bag them, after which they go back in some order or another...) Putting the cowl back on is more fun. I prefer to reattach it from the center out, front to back - and not to tighten the screws down until all are in. Then, tighten following the same pattern, front and center to the outsides, then along the hinges, and all of these with the Dzus fittings on the cowl sides, attached. It seems to be easier that way, than to do it all tight, and have to undo it to get it to fit! Steve McNew
15 Oct 2019 10:26 #3
Replied by Lawson Laslo on topic Removing the Cowling
Ours has been removed several times by my mechanic, I believe they just unscrewed it and pulled it off.
- Dennis Tar
14 Oct 2019 19:26 #4
by Dennis Tar
Removing the Cowling was created by Dennis Tar
I have a 415C / C85 and will be removing the cowling for the first time. Is it as simple / straight forward as removing the header tank sight gauge and unscrewing the visible screws?
Thanks for any advice
Dennis Tar
Dennis Tar
