Wing fuel tank leaks at fuel pickup
  • Lawson Laslo
16 Jan 2021 20:36 #1 by Lawson Laslo
Replied by Lawson Laslo on topic Wing fuel tank leaks at fuel pickup
If it still leaks you can use ezturn sealant on threads
16 Jan 2021 17:33 #2 by Matt Gunsch
Replied by Matt Gunsch on topic Wing fuel tank leaks at fuel pickup
no sealant, is used
  • Scott Monroe
16 Jan 2021 10:43 #3 by Scott Monroe
Replied by Scott Monroe on topic Wing fuel tank leaks at fuel pickup
Matt you mention no sealant regarding the crush fittings. How about thread sealant on the pipe threads going into the tank fitting? Thank you.
08 Mar 2020 12:55 #4 by Matt Gunsch
I looked thru 43.13, Cam-18 and the A&P handbooks and cannot find a listed torque for a AN775-5D Bolt, you could always use german torque, which is gootentite, ie tight enough not to leak.
  • Kathy McMurray
08 Mar 2020 07:44 #5 by Kathy McMurray
Replied by Kathy McMurray on topic Wing fuel tank leaks at fuel pickup
Matt, what is the torque on the fitting? It is an aluminum fitting on an aluminum tank. Thanks.
07 Mar 2020 11:48 #6 by Matt Gunsch
yes, they are crush gaskets and should be replaced, if everything is correct, they will not leak, no sealing compound needed
The following user(s) said Thank You: Kathy McMurray
