- Matco M. Cyl Brake Pressure Hose
- Dennis Tar
06 Feb 2021 06:37 #1
by Dennis Tar
Replied by Dennis Tar on topic Matco M. Cyl Brake Pressure Hose
Thanks for the tip on aircraft specialty. I ordered from them & price was good & service was excellent
03 Feb 2021 22:23 #2
Replied by Matt Gunsch on topic Matco M. Cyl Brake Pressure Hose
assembling your own hoses is easy, however, do not attempt to assemble it without using the mandrel, if you do, you run the chance of rubber being cut from inside the hose and clogging up something important.
03 Feb 2021 12:48 #3
Replied by John Jones on topic Matco M. Cyl Brake Pressure Hose
I have had good success with these folks for owner produced parts
www.aircraftspecialty.com/
or you could try a local brake or hydralic shop if you don't want to DIY
- Dennis Tar
03 Feb 2021 06:57 #4
by Dennis Tar
I will probably also make my own. Seems straight forward after watching a You Tube video from Aviation Tools Training.
01 Feb 2021 11:42 #5
Replied by Ronald Raty on topic Matco M. Cyl Brake Pressure Hose
I had this same issue. Brake hoses are sold by aircraft make and part number, and nobody lists anything for the Ercoupe. I finally had to buy a mandrel, the hose and fittings and make my own. It was fairly easy, once I figured out that the fittings screw onto the hose counter clockwise..
- Dennis Tar
31 Jan 2021 15:21 #6
by Dennis Tar
Matco M. Cyl Brake Pressure Hose was created by Dennis Tar
I have the Matco master cylinder that replaced the original Scott. I need to replace the pressure hose that needs to be 6 inches in length to meet the hard metal line.
Vern / Skyport apparently only has the original 8 inch hose that mated to the original Scott master cylinder. ( Univair only sells the hose by the inch to make your own)
Has anyone found a 6 inch hose with the right connectors or does it need to be custom made?
Thanks for any advice
