Flying Destinations
- Good flyways through the rockies?
06 Dec 2025 17:57 #7
Replied by Mac McCormick on topic Good flyways through the rockies?
Roger that and will do Ron. Thank you both John and Ron.
I found an almost simple method, I can map out a flight with Skyvector, export it as an FPL then Convert it with an FPL to KML file converter then load it into Google Earth. I also found a Google Earth overlay that gives all of the US Airspaces including Restricted, Warning, MOA, Danger, National Parks, etc. (No TFR) and importing the .KML gives me my flight path in red that I can then view the elevation with the Elevation tool. A bit kludgey but it works. Below is a quick down and dirty map I cobbled together from Wikepedia maps into one to give me a general idea of the Interstates. I use that with Skyvector to get the initial rough path. I'll see if I can get the Google Earth Airspace Overlay URL from my history and post it with the Converter URL.
06 Dec 2025 17:47 #8
Roger that thanks John.
06 Dec 2025 15:19 #9
Replied by Ron Holmes on topic Good flyways through the rockies?
I think there are a few guys flying across them. Ask James Good (watch his YouTube channel) and good luck... Let us know what you discover...
06 Dec 2025 14:31 #10
Replied by John Jones on topic Good flyways through the rockies?
I've done I-40 and I-80 with no issues. Take the usual mountain/desert flying precautions.
The following user(s) said Thank You: Kenneth Crofut
06 Dec 2025 10:18 #11
Good flyways through the rockies? was created by Mac McCormick
Scouring the wild wild web for flyways through the Rockies from New England, not much luck except for following 4 different interstates, I-40, I-70, I-80 & I-90. Anyone have flyways for crossing the Rockies in a 'Coupe?
