- Goodyear brake bleed problem cure
21 Oct 2021 13:18 #1
Replied by Warren Hampton on topic Goodyear brake bleed problem cure
the bleed screw I use is the screw on the disc of the cylinder
- Bruce Bennett
17 Oct 2021 13:59 #2
by Bruce Bennett
Replied by Bruce Bennett on topic Goodyear brake bleed problem cure
I use the standard red mil spec 5606.
- Anthony Fitzgerald
16 Oct 2021 15:43 #3
by Anthony Fitzgerald
Replied by Anthony Fitzgerald on topic Goodyear brake bleed problem cure
What brake/hydraulic fluid are you using?
- Bruce Bennett
12 May 2021 10:48 #4
by Bruce Bennett
Goodyear brake bleed problem cure was created by Bruce Bennett
Goodyear brakes are difficult to bleed because there is no bleed valve.
McFarland Aviation sells a bleeder valve (p/n MCBB-KT-2 , two required)
that will replace the drain plug on the bottom of each caliper. Works great.
Costs about $40 each but well worth it. I can finally bleed the brakes on my
Ercoupe in the normal, modern way. Hopefully a picture is attached.
