Ipad
  • TahoeTim
11 Mar 2016 22:58 #1 by TahoeTim
Replied by TahoeTim on topic Ipad
I'm at TVL South Lake Tahoe
11 Mar 2016 15:20 #2 by James Good
Replied by James Good on topic Ipad
Nice! Thanks for showing. Where are you based? I'm at KGOO, Nevada County Airport.
  • TahoeTim
11 Mar 2016 14:37 - 11 Mar 2016 14:44 #3 by TahoeTim
Assembled - mount holes in locations where the assembly can be removed without crawling under the dash
plate and Ram mount
aluminum plate painted black
Installed with "placeholders" in the bracket when the ipads are not in the bracket for a little pizazz. I had them made at a sign shop on platic backing for $10.
I centered them over the glove box holes.. When the ipad mini is in place, part of the tach is covered but I plan on moving the tach to the main cluster area anyway
Last edit: 11 Mar 2016 14:44 by TahoeTim.
11 Mar 2016 14:06 #4 by James Good
Would be interested in seeing your setup, TahoeTim.
  • Randy Hirsch AP
23 Feb 2016 09:22 #5 by Randy Hirsch AP
Replied by Randy Hirsch AP on topic Ipad
I'm a fan of an iPad mini on a knee pad with an iPhone on the dash for a backup.
  • TahoeTim
23 Feb 2016 09:07 #6 by TahoeTim
I am in the process of installing "Ram tab tite" mounts for my ipad mini over the glove box hole. I made a simple mod to the Ram mount to make it sit flat against an aluminum glove box cover plate. I will take some pictures today and post them here.
The mini fits perfectly.
