- Bleeding the Brake Lines
01 Nov 2021 18:44 #1
Replied by Matt Gunsch on topic Bleeding the Brake Lines
The bleed fitting is on the opposite end of the caliper from the brake line, usually a 1/4 wrench to open and close. easiest way to bleed is with a pump oiler fitted with a section of clear vinyl tubing that fits tightly on the oiler and bleed fitting.
- Larry McCartin
01 Nov 2021 16:10 #2
by Larry McCartin
Replied by Larry McCartin on topic Bleeding the Brake Lines
Thanks for asking. Cleveland.
31 Oct 2021 10:23 #3
what brake calipers ? goodyear or clevelands ?
- Larry McCartin
30 Oct 2021 19:40 #4
by Larry McCartin
Bleeding the Brake Lines was created by Larry McCartin
I just had to add Brake fluid to my Coupe for the first time in 6 years. It is a 1946 415-C. I can't seem to find the bleed screw on the back plates of the landing gear. With a car it is usually a nut with a hole in it for bleeding. Any advise? Regards, Larry N93436 Grants, NM
