- Adjust front strut height
21 Feb 2022 12:02 #7
Replied by Ronald Raty on topic Adjust front strut height
Here is a modification to raise the tail a few inches. This is to counter the changes of diameter of the nose tire. Don't use it to compensate for worn out rubber donuts on the MLG.
alphaaviation.com/ercoupe-main-landing-gear-spacers/
- Gianni Leonarduzzi
21 Feb 2022 10:43 #8
by Gianni Leonarduzzi
Adjust front strut height was created by Gianni Leonarduzzi
'46 Coupe 415-C with the Double Arm nose gear assembly.
The airplane is not level: I am about 2" lower at the tip of the vertical fin.
How do I adjust the gear? Spacers on the main gear? Can I lower the front gear?
Also, I get some shimming in the front gear at times when I land - checked tightness of all components in the front gear assembly and all of them are tight, except the collar round the strut, which has a bit of looseness - but I cannot figure out how to make it go away. Thanks in advance for your help.
