- Any Way to Measure Fuel Flow?
- Tim Cowden
21 Mar 2022 16:09 #1
by Tim Cowden
Replied by Tim Cowden on topic Any Way to Measure Fuel Flow?
Thanks John. I have your phone number and will call you for details.
Tim
Tim
21 Mar 2022 10:53 - 21 Mar 2022 10:53 #2
Replied by John Jones on topic Any Way to Measure Fuel Flow?
When you order your CGR-30P let them know you have a gravity fuel system. They will provide the "gold" fuel flow sensor that you install in the inlet line to the carb (will require new lines). That will give you the fuel flow indication on the CGR-30P. That is what I have on mine.
John
John
Last edit: 21 Mar 2022 10:53 by John Jones.
- Tim Cowden
20 Mar 2022 17:42 #3
by Tim Cowden
Any Way to Measure Fuel Flow? was created by Tim Cowden
I have a 1946 415C serial #670. As part of my complete instrument panel replacement I am purchasing a CGR-30P-40 Engine Management System to replace all of my engine instruments with one convenient modern unit. The CGR displays RPM, Fuel Flow, Oil Temp, Oil Pressure, Volts or Amps, CHT and EGT. I do not currently have any indication of Fuel Flow. I am assuming that I will just leave that unmeasured since I don't currently have a fuel flow gauge. Does anyone out there have a fuel flow gauge on their Ercoupe, and if so how is it measured?.
Thanks,
Tim
Thanks,
Tim
