- Why have a turn and bank?
- Randy Branson
25 Oct 2022 14:56 - 25 Oct 2022 15:00 #7
by Randy Branson
Replied by Randy Branson on topic Why have a turn and bank?
Pray tell me sir Super User, how I can slip my non-rudder pedaled Coupe? Other than temporarily turning opposite the wind?
Last edit: 25 Oct 2022 15:00 by Randy Branson.
17 Oct 2022 11:25 #8
Replied by Matt Gunsch on topic Why have a turn and bank
That is what I did, took out 16 lbs of vac instruments and hoses. I also installed the outside air temp probe and the AVlink for the AV-30, so I get ADSB traffic on the AV-30.
- Michael Hainen
17 Oct 2022 09:42 - 17 Oct 2022 09:48 #9
by Michael Hainen
Replied by Michael Hainen on topic Why have a turn and bank
I have one but don’t totally trust it. Don’t have an attitude indicator either, compass is fair butI hope to eventually dump both and the Venturi tube and lose some weight and install a UAVIONICS AV-30, get 13 pieces of useful info in one empty hole in instrument panel.
uavionix.com/products/av-30/
Last edit: 17 Oct 2022 09:48 by Michael Hainen. Reason: Add info
- George Polos
15 Oct 2022 07:55 - 15 Oct 2022 07:56 #10
by George Polos
Replied by George Polos on topic Why have a turn and bank?
Look into getting a Dynon Pocket Panel. It is a portable, GPS derived AHRS. Both I and my friend have 415-C Ercoupes use them and find them very helpful.
Last edit: 15 Oct 2022 07:56 by George Polos.
- RPJ
15 Oct 2022 02:46 #11
by RPJ
Replied by RPJ on topic Why have a turn and bank?
I was just about to post regarding flying without an attitude indicator. I also do not have a bank indicator but I do have a coordinator ball which is essentially just a level.
My question is, how does someone like me with only 6 hrs of training know when my steep turn is past 60 degrees without an indicator?? I just purchased the ercoupe and will be switching over to it after renting 172s. Should I add an attitude indicator/and or turn bank indicator as a new pilot? Or is there a trick to knowing when the turn is too steep?
- Paul Gilman
14 Oct 2022 18:14 #12
by Paul Gilman
Replied by Paul Gilman on topic Why have a turn and bank?
Ah a turn and bank in an Ercoupe.
I personally like it for a number of reasons.
There are times when a standard rate turn is required like at night or with fog. Or doing holding or procedure turns.
You also can check your rigging to make sure your turns are coordinated. Same for flying straight
Plus it is a light weight way to fill a hole in the panel.
