engine oil do you recommend for the the C.90 16F
  • 8419
28 Apr 2016 13:23 #1 by 8419
I've had the best luck with Exxon Elite 20W50, with a can of Avblend added with each oil change. Nothing sticks. The one time I went back to Phillips X/C with no additive my lifter started sticking. Went back and it's fine. Mine's a C85, but I don't think there is any appreciable difference here. Remember, these small Continentals are prone to sticking valves and lifters.
Larry
N99340
  • Grover Anderson
19 Apr 2016 08:14 #2 by Grover Anderson
Replied by Grover Anderson on topic engine oil do you recommend for the the C.90 16F
Which oil do you recommend for the c. 90 16F
Grover Anderson
  • Grover Anderson
26 Mar 2016 13:45 #3 by Grover Anderson
Which engine oil do you recommend for the C.90 16F
Grover Anderson
  • Grover Anderson
12 Mar 2016 17:22 #4 by Grover Anderson
engine oil do you recommend for the the C.90 16F was created by Grover Anderson
Which engine oil do you recommend for the C 90-16 F in an Alon Aircoupe.
Also can the camshaft be overhauled?
Thanks,
Grover Anderson
