- FAIRLEAD adjustment - ACCESS to tail and suggestions
- Andre Fodor
25 May 2023 07:39 #1
by Andre Fodor
FAIRLEAD adjustment - ACCESS to tail and suggestions was created by Andre Fodor
I need to adjust the FAIRLEAD bar on my Ercoupe.
Anyone can share how to gain access to the tail section? Did you place a 2x4 or plank between the ribs? Did you brace the tail so it would not tip down?
As to the adjustment, it seems that I just need to move the fairlead forward towards the nose to re-adjust its position vertically and this should self twist the cables back into the proper position.
Since I am there, I also plan to measure the cable tension.
Any suggestions, sharing previous experience, etc would be greatly appreciated.
A phone call would also be greatly appreciated if writing is too long to share experience.
407-443-5099. Andre. (N588BJ @ KORL)
