- header tank leak
header tank leak
- Nathan Bissonette
21 Apr 2024 10:10 #13
by Nathan Bissonette
Replied by Nathan Bissonette on topic header tank leak
I hope I'm not violating the rules of this website, but I'm writing to ask for BAD advice. Let me explain:
Scroll down the posts to see the "Hardware Hank" repair some prior owner made to the header tank shutoff valve on my 415-C. The valve is wet and the cockpit smells like gas. Discoloration indicates the tank itself may be leaking.
I spoke with my AP and several Ercoupe owners. I received lots of GOOD advice. Pull the tank ($1,500) and replace it with one from Univair ($2,800) or have it rebuilt by Safe Skies Aviation in Ohio ($2,000) or drill out all the rivets myself, then clean, patch, reassemble ($??). Vern at Skyport does not have a servicable used one.
Okay, that's the Right way to fix it but there goes all the money I set aside for the Annual in June and my insurance in November. What's the Wrong way? How about trying to extend the tank life with PRC sloshing sealer - anybody had success with that? What other low-buck options are there?
If you don't want to comment on this website for fear of looking like a cheakskate in front of others, email me at This email address is being protected from spambots. You need JavaScript enabled to view it.. I really appreciate ALL the advice I get from this group. Thanks in advance.
- Nathan Bissonette
01 Apr 2024 15:30 #14
Ken, I found this on another website:
ercoupe.groups.io/g/Tech/topic/52666189?...0::,,,0,0,0,52666189
Does removing the header tank really involve that much work? I'm amazed you found somebody to do it for so little money. Who's your A/P? I'd like to get a quote on mine.
29 Feb 2024 15:36 #15
Replied by Larry Snyder on topic header tank leak
If you try to replace a 5 gallon tank with a 6 gallon tank the filler necks are in different places. I’m amazed an A&P would R&R a header tank for $1000!!
- Kenneth Crofut
29 Feb 2024 15:34 #16
by Kenneth Crofut
Replied by Kenneth Crofut on topic header tank leak
Talk with your A&P. Mine pulled the header tank, cleaned it, pressure tested and solder fixed three leaks then reinstalled. Total price $1000. He said a new tank created or store bought would result in top cowling where neck goes through not lining up.
29 Feb 2024 06:04 #17
No amount of sealer will work for very long. JB Weld isn’t legal. Hate to say it, but the only real solution is pulling the tank and probably repairing/replacing it.
There are places that will build a new tank and use your old filler neck so it’s a “repair”.
Every time I’ve tried putting sealer on a leak it didn’t last very long.
- Jerry Nograsek
29 Feb 2024 05:52 #18
by Jerry Nograsek
Replied by Jerry Nograsek on topic header tank leak
Well first I would clean up the entire area and understand where the leak is originating. I would also see if that “fuel valve” is an aircraft part. Looks kind of “Ace hardware”. JB Weld wouldn’t be on my list of repair options
