- Annoying vibration
Annoying vibration
- 10035
03 Jul 2016 19:09 #1
by 10035
Replied by 10035 on topic Annoying vibration
Check the rubber isolation monts in the engine basket. Are you sure it is RPM related? Could it be an airspeed related airframe vibration?
Arlan Allen
N3989H
Arlan Allen
N3989H
- Kevin Gassert
02 Jul 2016 08:06 #2
by Kevin Gassert
Replied by Kevin Gassert on topic Annoying vibration
I know you said it started all of a sudden but do make sure the prop is indexed correctly and check the torque on the engine mount bolts.
Kevin
Kevin
- 10138
15 Jun 2016 19:43 #3
by 10138
Replied by 10138 on topic Annoying vibration
Well, here is the update..local AP thought aha, I believe it is a broken piston ring...so I authorized pulling the cylinder..nope..that's not it...it's like the Whack-mole game and each whack, I throw
More $$$$. Into the hole...
- 10138
09 Jun 2016 04:58 #4
by 10138
I have the C-85, metal prop. Yesterday I checked the mounts and could find nothing obviously loose.
The strange thing is it developed one day as I was flying pattern work, suddenly on one of my down-winds there it was.
09 Jun 2016 03:11 #5
Replied by Edward Moore on topic Annoying vibration
Which engine?
- 10138
08 Jun 2016 23:40 #6
by 10138
As soon as I burn some oil off I will do that ! Today I put 2 oz of MMO in each tank.
Flew it once around but the winds came up, plus I had an Erickson Skycrane in the pattern with me..always a joy...
