- Fuselage tank overflow elbow missing...
05 Oct 2024 20:14 #7
Replied by Brooks McNew on topic Fuselage tank overflow elbow missing...
Not sure if this will help, but here's a very short borescope video of my fuselage tank, taken when I was testing the new electric fuel pump.
You can see the input and overflow elbow.
04 Oct 2024 13:52 #8
Replied by Warren Hampton on topic Fuselage tank overflow elbow missing...
Matt is the header tank the Alon Tank? Not a 415 thank.
- James Davis
29 Sep 2024 11:24 #9
by James Davis
Replied by James Davis on topic Fuselage tank overflow elbow missing...
S/N 489....
I've changed my gauge float from cork to plastic one!
29 Sep 2024 01:59 - 29 Sep 2024 02:11 #10
Float cork is in need of replacement. Two diff tank what is your Coupes Serial number 2623 they changed tank for the header , one of the dif another is the filler neck placement. newer one the neck is more forward.
Last edit: 29 Sep 2024 02:11 by Warren Hampton.
- James Davis
21 Sep 2024 23:40 - 22 Sep 2024 11:18 #11
by James Davis
Matt Gunsch, I really appreciate this. Thank you very much.
Last edit: 22 Sep 2024 11:18 by James Davis.
21 Sep 2024 15:15 - 21 Sep 2024 15:21 #12
Replied by Matt Gunsch on topic Fuselage tank overflow elbow missing...
I have a bunch of pictures, not sure this will let me up load them all in one go, 415C Riveted Header Tank
Alon A2 Welded Tank
On My 415G, the return is a aluminum tube that has a joggle in it so it is higher than the inlet, and it's opening is closer to the filler neck.
Alon A2 Welded Tank
Last edit: 21 Sep 2024 15:21 by Matt Gunsch.
The following user(s) said Thank You: James Davis
