- Engine quit.
Engine quit.
- Michael Hainen
07 Apr 2025 13:10 #1
by Michael Hainen
Replied by Michael Hainen on topic Engine quit.
Worn out ignition switch. I have a brand new Cessna switch in the box and several new keys, bought for my other plane but I didn’t need to use it, found my problem.
04 Apr 2025 02:09 #2
Replied by Warren Hampton on topic Engine quit.
carb icing. Happen to me in S Cal once Cool air Sunny day.
- Kenneth Crofut
01 Apr 2025 17:31 #3
by Kenneth Crofut
Replied by Kenneth Crofut on topic Engine quit.
We have had a few inflight engine out and one actual on the highway landing at KTQH Tahlequah Oklahoma. The general consensus is carburetor ice. Due point and temperature have been close around here. Glad you are ok.
- Diane Bancroft
01 Apr 2025 06:52 #4
by Diane Bancroft
Replied by Diane Bancroft on topic Engine quit.
Very interesting. My mechanic will be out this week to see what is going on. Yes, it was a little scary. Thankfully there was a big field right below me, so I had time to see what the problem might be.
31 Mar 2025 21:51 - 31 Mar 2025 21:54 #5
Replied by Brooks McNew on topic Engine quit.
I can imagine how disconcerting that whole experience was for you. I'm sure we're all really glad that you figured out how to get the engine restarted!
I've got an old key switch that seems to work fine, but after reading about problems with them, I've kept a small wire cutter in a side pocket and I know *exactly* where the p-lead wires are so I can cut them if the ignition stops working for no apparent reason. It helps that my switch is installed near the bottom of the control panel!
I wish we could re-wire the ignition to use two simple toggle switches for the magnetos, like pretty much every twin engine airplane. It's cheaper, simpler, and if someone really wants to steal a plane, the the ignition key isn't stopping them anyway.
Last edit: 31 Mar 2025 21:54 by Brooks McNew.
- Diane Bancroft
28 Mar 2025 05:35 #6
by Diane Bancroft
Thanks for the suggestions. Thinking back, when I did the run up, checking the mags, when I turned the key, it did seem different. Can’t say why, but did seem different. Everything else was normal, so I didn’t give it another thought. Glad it did restart, but not a good feeling.
