- Tach hours reference speed?
13 Aug 2025 01:01 - 13 Aug 2025 01:12 #1
Replied by Brooks McNew on topic Tach hours reference speed?
Part 91? (Hippie voiceover)TBO is a state of mind, man.
The C-75/C-85 TCDS does not specify the tach harmonization RPM (where tach and hobbs would be equal) so I believe you're supposed to use a tachometer rated per factory original and/or rated at "max recommended cruise" but that's based on some secondhand knowledge.
eaaforums.org/attachment.php?attachmentid=9505&d=1700089416
Last edit: 13 Aug 2025 01:12 by Brooks McNew. Reason: Added link
10 Aug 2025 13:39 #2
Replied by Larry Snyder on topic Tach hours reference speed?
I thought of this because my tach shows I’m 80 hours past TBO but if you apply the 1:1.05 differential I’m still under TBO!!
- Frank Hamelly
10 Aug 2025 12:16 #3
by Frank Hamelly
Replied by Frank Hamelly on topic Tach hours reference speed?
That’s one of the best questions I have ever seen posted that I have NO CLUE as to what the answer is! Mike
09 Aug 2025 15:35 #4
I asked Grok. The answer was an airplane flying at 2400 rpm with a C-85 engine and a C-75 tach could record 1.05 hours for each engine hour.
09 Aug 2025 15:22 #5
Tach hours reference speed? was created by Larry Snyder
This one has got me. My airplane had a C-75 when I bought it. A couple years later I had it upgraded to a C-85. Nothing was done to the tach.
The hours displayed on the tach are calculated by the number of turns on the engine referenced to its typical rpm at cruise. Redline on a 75 is 2275 and redline on an 85 is 2575. So I am assuming that the hours on my tach are higher than they should be, since I’ve been cruising at 2400 rpm, 125 rpm above C-75 redline?
is there a different tach for each small continental?
Am I even on the right track here?
