- Windshield glue to glue weatherstrip to windshield and Nose?
20 Feb 2026 08:49 #1
Replied by Mac McCormick on topic Windshield glue to glue weatherstrip to windshield and Nose?
Roger that Brooks, thanks!
I've forwarded this onto my mechanic in case he needed something. He's a meticulous ex Marine aircraft mechanic and repairs a lot of vintage and new aircraft.
I've taken as many photos as I can of this project so I can document how to replace the windscreen and how to remove the rudder pedals and any other sundries I can add for us.Still TONS more to learn!
20 Feb 2026 00:24 #2
Replied by Brooks McNew on topic Windshield glue to glue weatherstrip to windshield and Nose?
I used
this product
(and a new length of weather strip) and it's been perfect so far.
First, I put the weatherstrip in place, and glued it to the fuselage only. I taped it in place and added a few shot bags to the wavy areas flat overnight. (The wavy areas were from the weather strip being unevenly rolled for shipping.) The next day, I could work with the windshield side without the weather strip moving around.
Next, do what I didn't do: Run a strip of blue painter's tape along the top edge of the weatherstrip. This should catch any squeezed out adhesive instead of it sticking to the window! I went along the weatherstrip, peeling it back as I ran a bead of adhesive along the bottom crease and then pressed it back into place. The next day I had a few squeeze-outs to clean up.
19 Feb 2026 21:04 #3
Windshield glue to glue weatherstrip to windshield and Nose? was created by Mac McCormick
Is there a recommended glue to use to glue the weatherstrips to the windshield and then also the weatherstrip on the bottom to the nose?
