- Installing C-90 in a 415-C
- Bruce Bennett
03 Dec 2016 21:53 #1
by Bruce Bennett
Replied by Bruce Bennett on topic Installing C-90 in a 415-C
Thanks all. Looks like a C-85 STC is in my future.
-Bruce.
-Bruce.
- Kevin Gassert
03 Dec 2016 19:35 #2
by Kevin Gassert
Replied by Kevin Gassert on topic Installing C-90 in a 415-C
You can pretty much change any continental into another by putting the correct parts in it but a c90 in any Ercoupe model G and below will need a field approval. The O200 crank STC does not because of the STC.
Kevin
Kevin
- Jack Arthur
15 Nov 2016 13:27 #3
by Jack Arthur
Replied by Jack Arthur on topic Installing C-90 in a 415-C
Here is the service bulletin number M 75-6R1 go to the Continental Motors website go support, service bulletins and print it out.
I think you will be surprised to see that you can convert small continentals but you have to do your research.
Hope this helps
Jack
Hope this helps
Jack
- Bruce Bennett
12 Nov 2016 13:45 #4
by Bruce Bennett
Would love to check out Continental's paperwork
and discover what is required compared to the
85 hp STC . Any one out there already know?
Can you reply with the link for others to see?
Per Larry's comment, a field approval is required
to keep it a C model. Unless my A&P has some
good connections, the 85 hp STC may be my
only reasonable paperwork option. -Bruce.
- Jack Arthur
11 Nov 2016 15:08 #5
by Jack Arthur
Larry is correct on being able to upgrade a c-85 with the STC for the 0-200 crank. But I have a document from Continental Motors that states that you can up grade any small continental to a C-90 with only several big changes. You have to install all the components of a c-90 into the case of a smaller motor and then re stamp the data plate on engine.
I will try and locate the paper if you need it.
Jack
Jack
05 Nov 2016 18:07 #6
Replied by Larry Snyder on topic Installing C-90 in a 415-C
First, as far as I know, a C-75 cannot be upgraded to a C-90. And if it could be, only with a field approval in a 415C. You can increase horsepower up to 10% without a field approval, I think. But you CAN upgrade to a C-85, because the type certificate explicitly allows it, and buy the STC allowing the installation of an O-200 crank, which results in an engine that will give a C-90, and even an O-200, a run for its money.
