- aileron trim tab
aileron trim tab
- Kevin Gassert
04 Dec 2016 13:06 #1
by Kevin Gassert
Replied by Kevin Gassert on topic aileron trim tab
No these were put on by people not familiar with Ercoupe maintenance that do not have the required manuals. I see Roy attached a link to the proper SB. All owners need the maintenance manual and the SB book.
Kevin
Kevin
04 Dec 2016 12:50 #2
Replied by Ronald Raty on topic aileron trim tab
Refer to paragraph 13 of ESM 35. It explains the aileron trim procedure. it involves a pair of pliers.
www.univair.com/content/ERC_SM35.pdf
- Ken Thompson
04 Dec 2016 11:59 #3
by Ken Thompson
Replied by Ken Thompson on topic aileron trim tab
Kevin, I have seen four or five inch long x two inch or so wide flat pieces of metal attached to the trailing edge of ailerons and horizontal stabilizers. Are these to assist with trim or rigging? Is that what you mean by 'tweaking?'
- Kevin Gassert
03 Dec 2016 19:19 #4
by Kevin Gassert
I have seen them and they look silly because they are not necessary. The ailerons are trimmed by tweaking the trailing edge.
Kevin
Kevin
- Reinaldo Cabrera
16 Nov 2016 19:33 #5
by Reinaldo Cabrera
aileron trim tab was created by Reinaldo Cabrera
Has any body install a trim tab in the aileron?
