- Floor Board Removal 415C
- Kevin Gassert
03 Dec 2016 08:46 #1
by Kevin Gassert
Replied by Kevin Gassert on topic Floor Board Removal 415C
Detach the cables from the rudder pedals. Disconnect the brake pedal from the top of the master cylinder. Remove the aluminum cover that is screwed onto the floor coving the gap at the control column bottom. Remove the panel the rudder pedals are attached to leaving the pedals on the board. Then remove the bottom floor board. This assumes you still have the original style two piece wooden floor.
Kevin
Kevin
- Chris Pirrmann
27 Nov 2016 19:08 #2
by Chris Pirrmann
Floor Board Removal 415C was created by Chris Pirrmann
Hi All,
I have a 415C with the rudder pedals STC. The wing tanks fuel line passes over the back edge of the floor board and the rudder pedals are attached to a board that covers the front edge of the floor board. In order to gain access to the bottom of the yoke, it appears I must remove one or the other. Does anyone have any tips, tricks or suggestions to make it easier than it appears?
Thanks
Thanks
