Nose gear fairing
  • Robert Regester
10 Oct 2019 09:35 #1 by Robert Regester
Replied by Robert Regester on topic Nose gear fairing
The fairing is used to aerodynamically streamline the nose strut when fully extended. If you have a snubber cable keeping it from extending then it is an airbrake. If you want to keep the snubber cable, take off the fairing. If you want a 1mph increase in speed, keep the fairing and take off the snubber.
Lot's of opinion on this.
10 Jun 2019 20:30 #2 by Chris Howard
Replied by Chris Howard on topic Nose gear fairing
The original design did not have the snubber cables. The fairing on the scissors is meant to provide aerodynamics once the nose wheel has extended fully after take off. There is allot of discussion on this topic in other places if you haven’t found your answer already.
  • J.R. Ranney
19 Sep 2018 15:17 #3 by J.R. Ranney
Nose gear fairing was created by J.R. Ranney
Does anyone know the purpose of the nose gear fairing?
Since it's not particularly attractive it must have some useful function. Is it an auxiliary front rudder? Is it only a fairing for the torque link?
J. R. Ranney
N3800H
