- ERCOUPE 415-C Right Side Door
13 Jan 2019 10:21 - 13 Jan 2019 10:37 #1
Replied by Matt Gunsch on topic ERCOUPE 415-C Right Side Door
dev.ercoupe.org/phocadownload/CoupeCaper...%20ads%20reduced.pdf
dev.ercoupe.org/phocadownload/CoupeCaper...7/'07%20December.pdf
dev.ercoupe.org/index.php/files/category...=89:april-09-revised
Last edit: 13 Jan 2019 10:37 by Matt Gunsch.
The following user(s) said Thank You: BILLY REEVES
13 Jan 2019 10:05 #2
Replied by Larry Snyder on topic ERCOUPE 415-C Right Side Door
The field approval is on this site under files>337s. But it’s for one airplane only. You might be able to use it to help get your own.
- Joey Shreve
13 Jan 2019 09:51 #3
by Joey Shreve
In case you don't know where the Capers are:
At the top of the page click on Files, Click on Coupe Capers, the select Older for the 07 or 08 section, then select the month then you can download the file by either clicking "Download" on the right; or right clicking and selecting "save link as" then select where you want to save it.
13 Jan 2019 09:47 #4
right at the top of the page, under files, then Coupe Capers dev.ercoupe.org/index.php/files/category/1-coupe-capers
- BILLY REEVES
13 Jan 2019 00:34 #5
by BILLY REEVES
I am totally unfamiliar with the newsletter (Coupe Capers) or how to find these articles. Would you please help me locate them?
12 Jan 2019 19:40 - 12 Jan 2019 20:00 #6
There is a write up about this plane in the Dec 07 and Sept 08 Coupe Capers
Last edit: 12 Jan 2019 20:00 by Matt Gunsch.
