- Lifting Locations?
Lifting Locations?
25 Mar 2020 20:00 #1
Lifting Locations? was created by Ronald Raty
When working on the landing gear, I supported the plane by bolting a couple of 2x4's to the wing mounting bracket to make a stand. I suppose you could suspend from those. That is pretty close to the CG, so the tail shouldn't need much support. When flying, the entire plane is basically suspended on those four bolts.
