- Can't identify carburetor. Can't be leaned.
23 Nov 2020 19:52 #1
Replied by Matt Gunsch on topic Can't identify carburetor. Can't be leaned.
Look at the Aug 2019 coupe Capers, there is a very good story on Stromberg carbs.
CARB MODEL ENGINE MFGR ENGINE MFGR ENGINE MODEL HORSEPOWER FUEL FEED
SETTING NUMBER
NA-S3A1 series carburetors with mixture control
A18033A –or- B CONT 3628 A-65 65 GRAVITY A-75 75 GRAVITY
A-80 80 GRAVITY
____________________________________________________________________________________
A30177 CONT 4631 A-75 (Stinson) 75 GRAVITY
50” HEAD
380162 CONT 40059 C-75 75 GRAVITY
380167 CONT 40590 C-85 85 GRAVITY
380171 CONT 36019 C-75 75 PRESSURE
380172 CONT 40636 C-85 85 PRESSURE
380174 CONT 24716 C-75-12 75 GRAVITY
380231-3 CONT
C-9012F 90 GRAVITY
380231 CONT
C-90 90 PRESSURE
391090 CONT
C-90 90 GRAVITY
391156 CONT
C-90 90 GRAVITY
391229-1-2 CONT 531126 C-90-14F 90 GRAVITY
391257 CONT 531157 C-90-14F 90 GRAVITY
391716-1 CONT
A-50 50 PRESSURE
“ “ “ A-65 65 3 PSI /
“ “ “ A-75 75 .048” FLOAT
“ “ “ A-80 80 DROP __
SETTING NUMBER
A-80 80 GRAVITY
50” HEAD
380231-3 CONT
C-9012F 90 GRAVITY
380231 CONT
C-90 90 PRESSURE
391090 CONT
C-90 90 GRAVITY
391156 CONT
C-90 90 GRAVITY
391716-1 CONT
A-50 50 PRESSURE
- Michael Hainen
23 Nov 2020 16:29 #2
by Michael Hainen
Replied by Michael Hainen on topic Can't identify carburetor. Can't be leaned.
more info on the STROMBERG UPDRAFT CARB MODELS
www.thecarburetorshop.com/STROMBERGUPDRAFTCARBURETORS.htm
- Larry McCartin
23 Nov 2020 13:17 #3
by Larry McCartin
Replied by Larry McCartin on topic Can't identify carburetor. Can't be leaned.
Michael, YOU ARE THE MAN! What great info. I'm going to check it out ASAP. Regards, Larry N93436 Grants, New Mexico
- Michael Hainen
23 Nov 2020 12:35 - 23 Nov 2020 12:40 #4
by Michael Hainen
Try these guys to help you identify your carburetor. These guys offer a carb ID service if you read down the page for $20 .
www.thecarburetorshop.com/Carburetor_ID.htm
Once you are there look at the listing of updraft carbs, used on many types of machines industrial, marine, Model T, and on and one.
Also look at the listing of under "TRACTOR CARBS", dozens and dozens of tractors listed.
Last edit: 23 Nov 2020 12:40 by Michael Hainen. Reason: more info
23 Nov 2020 06:35 #5
Replied by Larry Snyder on topic Can't identify carburetor. Can't be leaned.
I’m assuming it’s a Stromberg carb. If it’s legal for your airplane, it should be able to lean it. Many are wired full rich with no control. You con install a mixture control. If your carb is off a tractor, it’s not legal, but I don’t think very many tractors have updraft carbs...
- Larry McCartin
22 Nov 2020 23:04 #6
by Larry McCartin
Can't identify carburetor. Can't be leaned. was created by Larry McCartin
The carb on my 1946 415C cannot be leaned. I move from Tucson to Grants, New Mexico at 6400 MSL. So the engine (85 hp) is running way to rich and can't handle the air density even when the temp is 50 degrees F.. I bought the engine and carb from a fellow who had a fire that destroyed the plane in his hanger, but the brand new C85 was in perfect condition with only 98 hours on it. Only later did I learn it had this type of carb. Went to a Coupe get together at Lake Havasu a few years ago and asked some of the guys to look at it. One of them told me it was a carb used on farm tractors from the 1940's and he thought is was an option from the factory (?) He said he had seen one in the past on a Coup also. Well, it is rather dangerous trying to fly since I moved here. I'm a retired school teacher and there is no way I can afford a new carb. Any ideas about changing the mixture for a much higher altitude would be appreciated. Regards, Larry Mccaartin Grants New Mexico (520) 444-4390
