- Ercoupe Light Sportl
22 Apr 2022 17:28 #1
Replied by Larry Snyder on topic Ercoupe Light Sportl
You can try to slim down your airplane. I removed an old WW II era attitude indicator and lost 17 pounds! I removed all instruments except those required and the Venturi and used my GPS and phone for information. Went to an alternator. You can also go to a lightweight starter and battery. I’ll bet you can remove most of the 80 pounds difference. And you know, burning 5 gallons an hour means that every hour of flight you are 30 pounds lighter!
The advantage of light sport? You need no medical other than your driver’s license.
- John Farrell
22 Apr 2022 17:19 #2
by John Farrell
Ercoupe Light Sportl was created by John Farrell
Considering an ERcoupe which is" light sport
" (1320lbs). Just sold my ERcoupe 1948 415E with GW of 1400 and EW 936. I could carry myself (205) and about 14 gallons of fuel and a passenger weighing 205 and be at 1433. C-85 old engine. With a light sport GW of 1320 lbs, I figure it would be difficult to carry a passenger who weighs more than 120 lbs. and have more than 10 gallons in the tanks. Would appreciate any comments/ experience of other long time ERcoupe light sport folks in loading your planes. Also, what's the advantage of light sport as far as the FAA regs go?
