- G-HARY
G-HARY
28 Jun 2024 00:16 - 28 Jun 2024 00:27 #7
Replied by Warren Hampton on topic G-HARY
Is that not the one that the Alon Don Abbot has now down at Page Field in Ft Myers Fla. it is something like that. All Alon A-2s had C90-16F with V pumps This Alon came out of Canida. But as Matt thy too run V syst. Then some of the early A2s may have come with the C90-12F
Last edit: 28 Jun 2024 00:27 by Warren Hampton.
27 Jun 2024 18:19 #8
Replied by Larry Snyder on topic G-HARY
G-HARY is an Alon and I think anll Alons were equipped with a vacuum pump. So why any venturis? Best to follow the vacuum tubing and see what your vacuum instruments are running off of.
27 Jun 2024 18:11 #9
Replied by Matt Gunsch on topic G-HARY
And where do you think the vacuum to run the instruments comes from? it is from the Venturis. There are only a few sources of vacuum to run instruments, Venturis, or a wet or dry engine driven vacuum pump.I've noticed that this airplane has two venturis installed. Since it has a vacuum system, anyone have knowledge on why he has the venturis?
Ed
- Edward Woerle
24 Jun 2024 10:29 #10
by Edward Woerle
G-HARY was created by Edward Woerle
Ed
Ed
