Suggestion Box
- Erratic Loss of 200rpm After Takeoff
This is the optional category header for the Suggestion Box.
- Dean Weichmann
25 Jul 2018 06:36 #1
by Dean Weichmann
Replied by Dean Weichmann on topic Erratic Loss of 200rpm After Takeoff
Hi Dennis, this sounds similar to my experience not long ago. My 46 Ercoupe lost power as you described while attempting power on stalls. This did not re-occur a week later in cooler weather. I posted this under Ercoupe specific.
- Denis Jacques
21 Jul 2018 09:27 #2
by Denis Jacques
Erratic Loss of 200rpm After Takeoff was created by Denis Jacques
Hello, my '69 has been losing around 200rpm and running rough after I get to 500' during climb out. It did it two flight ago, ran perfect last flight, then did it agin this morning. The header fuel cap vent is fully open and air filter is good. What could be causing this issue? I live in Florida and this morning it was 81F and 90% humidity. Could carb ice be a possibility? Any input will be greatly appreciated as I will not be flying the airplane again until the issue is diagnosed and fixed. Thank you so much.
