Fuel Primer Leaking
24 Aug 2022 13:43 #1 by Randy Branson
Replied by Randy Branson on topic Fuel Primer Leaking
Mine was sticking and  leaking too. i took it  apart and rebuilt it.  works fine now.
21 Jun 2022 07:44 #2 by Larry Snyder
Replied by Larry Snyder on topic Fuel Primer Leaking
It’s an easy fix. I’ve used Teflon string to pack it, but I’m sure there are several solutions.
  • Donato Martino, SP-CFI
20 Jun 2022 21:43 #3 by Donato Martino, SP-CFI
Fuel Primer Leaking was created by Donato Martino, SP-CFI
Can a leaking fuel primer be repaired?  Are there O rings that can be replaced?
Thank you
