- Garmin GDL 82 Issue
Garmin GDL 82 Issue
07 Jun 2023 07:55 #1
Replied by Larry Snyder on topic Garmin GDL 82 Issue
You can always check if your ADS-B out is working properly by submitting a Public ADS-B Performance Report (PAPR) request.
adsbperformance.faa.gov/PAPRRequest.aspx
- George Polos
07 Jun 2023 07:39 #2
by George Polos
Replied by George Polos on topic Garmin GDL 82 Issue
Larry, The other day my friend and I flew our Ercoupes together on a short cross country and his ADSB track on FlightAware was perfect up and back. He has a Garmin 335 which provides a transponder and ADSB-out. Mine cut out after a short segment up and never even recorded anything coming back on FlightAware. Of course I can get the tracks on ForeFlight but not seeing them on FlightAware makes me wonder if ADSB-out is working. My transponder was recently checked and passed the test. I have no idea what the problem might be.
06 Jun 2023 13:25 #3
I’m still trying to figure out how ADS-B works. FlightAware seems to only know about trips where I talk to ATC for flight following. It rarely sees me at the very beginning or end of a flight, I figure that’s because I don’t reach a tower until I’m pretty high in some areas of Arkansas. If someone could fully describe the ADS-B to FlightAware relationship I’d sure live to hear it!
- George Polos
06 Jun 2023 12:32 #4
by George Polos
Garmin GDL 82 Issue was created by George Polos
I have a Garmin GDL 82 installed that works with my Narco AT 150 transponder to provide ADSB-out. The problem I run into is often when I look on FlightAware there are missing segments for my route. Any suggestions for troubleshooting this issue?
