- Ercoupe O-200 STC Prop question
22 Sep 2025 11:19 #13
Replied by Larry Snyder on topic Ercoupe O-200 STC Prop question
I’d call Alpha Aviation and ask. I know that many complaints I’ve heard in the past about the O-200 STC was the limited choice of propeller that does not let you take full advantage of the engine.
- Randall Hirsch
22 Sep 2025 11:07 #14
by Randall Hirsch
Ercoupe O-200 STC Prop question was created by Randall Hirsch
Using a new IA this year for the annual inspections on my Ercoupe and my friends 415-D with an O-200 STC. This IA noticed that the STC (STC SA2628WE) specifies only one prop a McCulley 1A101/DCM 6948. This 415-D has a 1A100/DCM 6950 - which is fine for the O-200 and is listed on the TC for the engine, just not in the STC for the O-200.
Has anyone else run into this issue before? Is everyone out there with an 0-200 running a 1A101/DCM 6948?
Thanks,
Randy Hirsch
Thanks,
Randy Hirsch
