- Ad 2012-08-06
Ad 2012-08-06
31 Dec 2025 10:29 #1
Replied by John Jones on topic Ad 2012-08-06
I've used the gps method per para (g)(
and found my Alon's airspeed indicator error almost identical to that shown in the "Flight Manual" from Univair (that is a copy of what Alon provided to the British). There are several spreadsheets available online, requiring flying either a triangular or rectangular course at different airspeeds and noting the ground speed on each leg, i.e. @ 50, 65,80, 95,110, 125 indicated. Pro tip-still air helps.
- Scott Thiel
30 Dec 2025 18:46 #2
by Scott Thiel
Ad 2012-08-06 was created by Scott Thiel
How did you do the 4yr airspeed certification required by this AD?
