- Alon A2 Propellor
Alon A2 Propellor
- Gordie Meade
17 Nov 2017 14:45 #1
by Gordie Meade
Replied by Gordie Meade on topic Alon A2 Propellor
Mine is a C90-16F. It has a McCauley 7153 prop. I was thinking about trying a Sensenich 7153 since the McCauley is the original 1967 prop and design has improved some since then. Anyone using a Sensenich on a C85 or C90?
- John Chirtea
16 Nov 2017 22:54 #2
by John Chirtea
Replied by John Chirtea on topic Alon A2 Propellor
Is your engine a C-90?
- John Chirtea
16 Nov 2017 22:51 #3
by John Chirtea
Will check mag timing. Thanks.
16 Nov 2017 22:39 #4
Replied by Warren Hampton on topic Alon A2 Propellor
My 67 A2 had a 71-53 I fly out of a pave runway and A down hill dirt strip aways climb well even with Two guys 260 &230 have you check Mag timing?
- Gordie Meade
14 Nov 2017 20:50 #5
by Gordie Meade
I'm almost at sea level, and with the 71/53 I get 2375 static. In the dead of summer with density altitude of 2800 feet (field is 225) and the canopy cracked open, I get about 4-500 fpm. In the winter with the canopy closed and density altitude of 1200 feet, I get 7-800 fpm.
Others would know better than I would but 2350 with that prop seems pretty anemic.
- John Chirtea
14 Nov 2017 20:42 #6
by John Chirtea
Hi Gordie:
My static rpm is 2350 with the 71/46. Although I think this is a climb prop, my climb performance is terrible. I take off on a grass strip, and know this slows me down. Does you 71/53 give you a good climb??
Thanks
Thanks
