Engine Removal
  • Mike Then
03 Dec 2021 06:29 #1 by Mike Then
Replied by Mike Then on topic Engine Removal
Thanks Warren.  I see now the service manual doesn't say to remove the exhaust.  Must be a carry over from 415 service verbiage.
Mike
03 Dec 2021 01:52 - 03 Dec 2021 01:55 #2 by Warren Hampton
Replied by Warren Hampton on topic Engine Removal
No, with the most C90 there is a an eye on top of the engine to lift the eng. with.  You do not have a wrap-around exhaust like the 415s. So it is a disconnect and remove. Just be sure the tail is supported when you pull the eng off the mount... It gets tail heavy fast.
Last edit: 03 Dec 2021 01:55 by Warren Hampton.
  • Mike Then
01 Dec 2021 21:26 #3 by Mike Then
Engine Removal was created by Mike Then
I need to remove the C-90 from my M10.
The M10 service manual outlines removing the engine mount with the engine, then removing the engine mount.   I would guess the Alon service manual calls the same process, but I do not know.
I understand this will allow me to inspect the engine mount, but other than that is there a reason to remove the engine mount with the engine?  Seems like unnecessary work.
Mike
